How do you fasten-in electronic boxes?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=46121
Author:  unkabob [ Mon Aug 03, 2015 11:46 am ]
Post subject:  How do you fasten-in electronic boxes?
This is my first electric instrument (U-bass) and the electronics package came with wood screws as fasteners, is this normal? I would have expected machine screws (bolts) with some sort of tee-nut or threaded inside frame.
I guess that my questions are is this normal and what reinforcement do you use inside.
Any help would be appreciated.
Bob :ugeek:
Author:  Cush [ Tue Aug 04, 2015 8:32 am ]
Post subject:  Re: How do you fasten-in electronic boxes?
I have seen some boxes that have wood screws and some with machine screws. The machine screws threaded into a stamped steel mounting plate or ring shaped to match the box. I think the machine screws are superior to wood screw mount. One wood screw mount that I saw was a box in a low cost guitar that had come loose from the side. They had no brace under the side wood at all so I added a couple braces and reattached the screws. So far as I know it is still in place.
Matt
Author:  unkabob [ Wed Aug 05, 2015 9:20 am ]
Thanks!
I will back-up the sides with side material (cross-grain) and try the screws. After I close the box, any repair will be very difficult through the double-puka sound holes.
Bob :ugeek:
